Unichip para toyota corolla 1.8l
features escribió: Adds up to 15hp &13ft-lb and also optimizes settings to take full advantage of all bolt-on accessories.
Easily plugs into the stock ECU & ECU harness in minutes , no programming necessary .
Realizes the full potential of Aftermarket add-on's like Cold-Air-Intakes & exhaust systems , as each kit comes pre-mapped for the exact set-up of each car or truck.
No end-user tuning necessary , just plug the kit into the car & you're ready to go.
Easily upgradeable for future add-on's.
Each kit comes with two maps : a low octane performance map & a high octane performance map, switchable from within the vehicle.
Fully tuneable by a Unichip Custom Tuner for customized add-on's . This basically means that the Engine Management
System in your ride is now as tuner friendly as the most advanced Standalone systems in the world , without sacrificing any of the factory features. This feature is unmatched by any reflash-tuning or other similar product.
Plug 'n Play harnesses are fully Flux capable - purchase Flux when you purchase the Plug 'n Play kit or upgrade later - Flux simply plugs into the Unichip Plug 'n Play harness.
Plug 'n Play kits are removed from the vehicle in minutes , returning the vehicle to stock tuning , without leaving a footprint of ever having been modified (a feature which reflash-tuning cannot match).
ROADSPEED-LIMIT Removal now available . Write : "Remove roadspeed limiter" in the comments section of the checkout . This feature is only available on this website.
http://www.unichip.us/vehicle/vehicles/ ... orolla-18L
Algunos habian preguntado... aca encontre el chipote para nuestros toyos!
yotota
Administrador
Administrador
City: Canning
Vehículo - Marca: Peugeot
Vehículo - Año: 2020
Re: Unichip para toyota corolla 1.8l
Mensaje por yotota »
Damian Audio Store
Provincia/Estado: Bs. As.
City: Z. Norte
Vehículo - Marca: Dogde
Vehículo - Modelo: Journey SXT
Mensaje por Damian Audio Store »
Bueno, ya q tienen la info, Quien es el primero???
Y... seguramente vos.... :cool
Yo particularmente estoy contento con mis 132 cv (preguntale a Checho sino...) y mi bajisimo consumo....
En San Isidro hay otro conocido que ademas tiene rodillos que se puede ir a probar. Se llama SportChips y no se si tienen para Corolla http://www.sportchips.com.ar/MakeList.asp, habria que preguntar, no?
by.andres
Vehículo - Modelo: corrolla
Mensaje por by.andres »
Hikaru me parece que la perla tiene 136 CV. Los G 10 tienen 132.
yotota
Administrador
Administrador
City: Canning
by.andres escribió:Hikaru me parece que la perla tiene 136 CV. Los G 10 tienen 132.
UHHHG!!! Se atrevió a corregir a Hikaru!!! :perdido
En el próximo encuentro le saco una foto torcida, vas a ver.....
Ojala tenga 136cv, pero es el mismo motor 1ZZFE de 132cv que tenes vos. Aunque con un cambio de parámetros en la ecu se podrían conseguir. De hecho hay versiones del mismo motor que van entre los 107cv y los 145cv. Claro que la mejora en la performance, siempre se lleva unos litros mas de combustible.... :pensando
Igual, sea uno o lo otro no ando usando esos 4 mantungos adicionales, por lo que esta todo :cool
Sip es así...el 1.8 del G9 da 136 cv , mientras que el del G10 132 ...debe ser x algo "electrónico" . Algo así pasó con varios de los últimos modelos de Renault...que con la misma cilindrada daban 110 cv y ahora 102 o 105 dependiendo del modelo...
gustavomon
Mensaje por gustavomon »
Con un consumo mixto siempre arriba de 11 km por litro, Toto no necesita ningun chip.
Gustavo
Yo la verdad, no me animo ...
